How to determine size of RAM present in controller
The Realview MDK toolchain provides a number of $$ linker generated variables with the base, limit and size of sections.
What I need is such a variable that holds the total amount of ram present in an entire region but I can not seem to find this.
To be more specific, the generated scatter file is as shown below and what I need is a $$ linker generated variable returning the second numeric value of this line:
RW_IRAM1 0x10000000 0x00008000
So 0x00008000
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x00000000 0x00080000  {    ; load region
size_region
  ER_IROM1 0x00000000 0x00080000  {  ; load address =
execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  RW_IRAM1 0x10000000 0x00008000  {  ; RW data
   .ANY (+RW +ZI)
  • Thanks for your reply,
    these are the ones I tried. Variable Image$RW_IRAM1$ZI$Limit is set to the limit of the zero initialized section. So this variable only tells how much of the RAM is used. What I need is a variable identifying the physical amount of memory present. I tried all variables I could find in the linker manual but none of them seems to provide this value. Still I think there should be one, the linker knows it.
