Heya mates.
Just starting out (Jena151 tutorial 30/40) and thought I would try my handy work at a target that has lights.
Tuts 9 & 10 talk about ADD, but I can't seem to extend what I've read to this situation.
The issue I am running into is that the target actually loads the code which in turn loads the project after you click OK on the form. You then are in the control screen.
Truthfully I am a little lost in all the assembla stuff (LOL) and was wondering if there were any good tutorials (Jena's are great thus far but I'm looking for something more in depth with just to beat this app) or if my approach is just plain wrong.
Any suggestions would be greatly appreciated. Best Regards, wmt
"(Jena151 tutorial 30/40)"
What's that?
Is it a Keil document?
"Tuts 9 & 10"
What are they?
"the target actually loads the code which in turn loads the project"
No, that is not the way that the Keil tools work - hence I guess you have the wrong forum?
"after you click OK on the form"
What form?
"You then are in the control screen."
What control screen?
"Truthfully I am a little lost"
Yes, I think you are!
"in all the assembla (sic?) stuff"
You're not talking about MS .NET assemblies, are you? If you are, then this is certainly the wrong forum!
"if my approach is just plain wrong."
Posting on unrelated forums is definitely not a good approach!
If this is actually relevant to Keil, then you need to explain what you're talking about - remember that nobody here knows anything about you, your background, or your project other than what you clearly & explicitly explain in your post!
"Any suggestions would be greatly appreciated"
Explain what you're actually using, what tutorial you're actually referring to (give the URL), etc, etc,...
Giidance here:
catb.org/.../smart-questions.html
