RTX-OS ->Need Help for using interrupt on at91sam7x256
Hi,all
I want to use interrupt in rtx-os for at91sam7x256 .
1- usart interrupt
2- external interrupt.
3- timer interrupt
Please help me how to config this peripheral for using in interrupt.
Thank you.
Amir Zendehdel
  • You titled your post, "RTX-OS -> Need Help for using interrupt..."
    But your question was, "help me how to config this peripheral"
    So which is it that you actually need to know - how to use RTX-OS, or how to configure the peripheral?
    How to configure RTX-OS will be descrined in the RTX-OS manuals;
    How to configure the hardware peripherals of the at91sam7x256 will be described in the at91sam7x256 documentation.
  • hello Andrew
    Thank you very much,i dont know all of email that replay to my mail from keil.com was going to my spam mail.
    dear friend i was used At91sam7x256 board and doing all example of rtx-os and all of them work goooood.
    but when i was config usart interrupt same as normal mode(none RTX-OS) then each time its interrupt happen system fall in halted state.
    in rtx-os documentation i saw a little thing about config interrupt in rtx-os .
    ------------------------ Keil Doc -------------------------------------------------
    void isr_evt_set (unsigned short event_flags, OS_TID task);
    A typical task intended to handle interrupts will have the following structure:
    void Task3 (void) {
    while (1) { os_evt_wait_or (0x0001, 0xffff); // Wait until ISR triggers an event … // Handle the interrupt } // Loop and go back to sleep
    } The actual interrupt source will contain a minimal amount of code.
    void IRQ_Handler (void) __irq {
    isr_evt_set (0x0001, tsk3); // Signal Task 3 with an event EXTINT = 0x00000002; // Clear the peripheral interrupt flag VICVectAddr = 0x00000000; // Signal end of interrupt to the VIC
    if keil have more document please help me.
    Please help me : for example if i want to use serial rx interrupt
    Manyyyyyyyyyyyyyyyyyyyyyyyyyyyy many thanks
    Amir
  • Hello Amir Zendehdel,
    Please check example .\Keil\ARM\Boards\Atmel\AT91SAM7X-EK\Hello.
    This example shows how to configure timer, UART, Vectored Interrupt Controller, ...
    Best Regards,
    Martin Guenther
  • Hello,Martin
    Thank you very much.
    i see its example, i think it may simple ,tTC was simple, i guess RX intrrupt will the same.
    thank you for your useful guide.
    Best regard & have nice time
    Amir
  • Hello all
    Finally im find an example for serial interrupt in RTX-OS mod
    \Keil\ARM\Boards\Atmel\AT91SAM7X-EK\RL\USB\RTX_CDC\serial.c
    Thank you from all of friend that guid meeeeeeeeeeeeeeeeeeee
    please enjoy KEIL
    RTX-OS IS GOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOD
    Amir
