LPC2378: Interrupts
Hi I use an LPC2378 and try to timer1 to generate an interrupt, but it not happen.
VIC begin:
static void initVIC(void)
    uint32 *vect_addr, *vect_prio;
    int i = 0;
    VICIntEnClr = 0xFFFFFFFF;
    VICProtection = 0x0;
    VICSoftIntClear = 0xFFFFFFFF;
    VICIntSelect = 0x0;
    VICSWPriorityMask = 0xFFFF;
    for(i = 0; i < 32; i++) {
        vect_addr = (uint32 *)(LPC2378_VIC_BASE + VECT_ADDR_INDEX + (i*4));
        *vect_addr = 0x0;
        vect_prio = (uint32 *)(LPC2378_VIC_BASE + VECT_PRIO_INDEX + (i*4));
        *vect_prio = 0xF;
    return;
set ISR:
void installIntr(pISR intSR, eIF IRQorFIQ, uint32 prio, uint32 vectorNum)
    if( IRQorFIQ == bIRQ ) { VICIntSelect = 0x0; }
    else if( IRQorFIQ == bFIQ ) { VICIntSelect |= 0x20; }
    VICIntEnable |= 0x20;
    uint32* VectBasePrio;
    VectBasePrio = (uint32*)&(VICVectPriority0);
    pISR* VectBaseAddr;
    VectBaseAddr = (pISR*)&(VICVectAddr0);
    VectBaseAddr= (pISR*)((&(VICVectAddr0)) + (vectorNum*4));
    *VectBaseAddr= intSR;
    VectBasePrio = (uint32*)((&(VICVectPriority0)) + (vectorNum*4));
    *VectBasePrio = prio;
    return;
disable ISR with:
    MRS     R0, SPSR
    ORR     R0, R0, #0xC0
    MSR     SPSR_c, R0
    MOVS    PC, LR
... and enable with the same but ORR -> BIC.
Also IRQ int set to: ldr pc, [pc, #-0x120]
Any help much grateful :)
0
