Controller : LPC2368(ARM 7)
Issue : Battery RAM values not storing . Junk values getting stored on it.
Hi People ,
I am using LPC2368 (ARM7) . I am facing the following issue with the Battery backup RAM .
My Pclk for Battery backup RAM is Pclk = Cclk / 4 ;
And I am storing data as shown below
#define BATTERY_RAM_BASE_ADDRESS 0xE0084000 /* ALLOCATION */ #define BSR_Data1 (*(volatile unsigned long*)(BATTERY_RAM_BASE_ADDRESS 0x000)) #define BSR_Data2 (*(volatile unsigned long *)(BATTERY_RAM_BASE_ADDRESS + 0x004)) #define BSR_Data3 (*(volatile unsigned long *)(BATTERY_RAM_BASE_ADDRESS + 0x008))
As Static Battery RAM can be accessed only word-wise(32bit only)
Note : The Battery RAM is a 2 kbyte static RAM residing on the APB bus. The address range is 0xE008 4000 to 0xE008 47FF. The SRAM can be accessed word-wise (32-bit) only.
And I store it as ,
Unsigned int Store_Data; Store_Data = BSR_Data1 ; And Reading it as BSR_Data1 = Store_Data ;
Is this the Correct way ?
Because after a day all the data that I store is getting erased.
Thanks in advance, Pls help me out guys on this issue.
Regards, Samjith Wasim . A
How are you sure that the data was correctly stored in the first place?
By doing this I can read/write the first data alone correct ?
for consecutive data I will use like this
Store_next_data = BSR_Data2;
And read it as BSR_Data2 = Store_next_data;
is this the correct method ??
Is this the correct way of pointing data to Battery RAM .
How do I write/read a complete structure of each 32 bit data on to the Battery RAM ?
Thanks in advance
How to check whether variables stored in first place ??
The method of storing/reading my word-wise data is this correct ?
Guys can you Please help me on this issue as soon as possible.
Regards, Samjith
If BSR_Data1 is a variable in the battery-backed memory, then this is a write, and not a read:
To test if the memory works, you should write a significant amount of data - together with a checksum, CRC or similar, and then power off the unit and wait for a while. Then power up and read out the values - the checksum should still be correct.
Have you remembered to connect the VBAT signal to a battery or super-cap?
since you do not state clock speed or type if BBRAM, is the write/read timing slow enough to satisfy the requirements of the BBRAM?
This has come up before in other contexts.
Note that the NXP LPC2368 has internal 2kB battery-backed RAM (if external power is applied to the dedicated supply pin)
Have you checked the voltage of the battery?
Guys Thanks a ton ,
I just checked by Bat Voltage and found to be drained ..
I will come back after checking it with in a day or two.
