Hi!
How make preprocessor error? #error - not work in keil 4.12 (ARM)
#ifdef IO16_A CPU_CLOCK = 50; #elif IO16_B CPU_CLOCK = 25; #elif IO16_C CPU_CLOCK = 8; #else
#error "No select device type!"
#endif
What do you mean by "not work" - do you get any error message(s) ?
You almost certainly don't want to do that. That needs to be either
#if IO16_A CPU_CLOCK = 50; #elif IO16_B
or
#if defined(IO16_A) CPU_CLOCK = 50; #elif defined(IO16_B)
I find out: generate syntax error
#ifdef IO16_A if(strncmp(&FileName[0], "main_IO16_A", 11) == 0 && strncmp(&FileName[NameLen - 6], "_C.bin", 6) == 0)
#elif REL6HC_A if(strncmp(&FileName[0], "main_REL6HC_A", 13) == 0 && strncmp(&FileName[NameLen - 6], "_C.bin", 6) == 0)
#elif COM2_C if(strncmp(&FileName[0], "main_COM2_C", 11) == 0 && strncmp(&FileName[NameLen - 6], "_C.bin", 6) == 0)
#elif REL12LC_A if(strncmp(&FileName[0], "main_REL12LC_A", 14) == 0 && strncmp(&FileName[NameLen - 6], "_C.bin", 6) == 0)
#elif IR4_B if(strncmp(&FileName[0], "main_IR4_B", 10) == 0 && strncmp(&FileName[NameLen - 6], "_C.bin", 6) == 0)
#else "Error message: No type Device HTTP_CGI" //compiler generate syntax error
#endif { ErrorChannel = 0; return; }
That'll be because it's not valid 'C' syntax!
Did you copy & paste the exact text from your source code?
And still using the old and deprecated #ifdef instead of the newer #if defined(xx) and mixing it with the completely different #if - haven't you figured out that #if and #ifdef does not do the same thing?
I find out:
No --- you're deluding yourself. You obviously didn't find out anything. You're just making the same mistake 5 times instead of the original 2 times.
