Flash C language program into Transceiver
Hi everyone,
I'm working on a remote control car and I'm figuring out on how to flash C language program into the Transceiver through C8051F0XX target board. I'm using C8051Xf0xx target board and Enocean TCM120 (Transceiver) to do the RF communication. So I'm wondering if my connections are right. Or is there other way to flash C program into my transceiver.
At the moment, I've connected the transceiver to the target board as below:
Transceiver Target Board
Pin 7(RX) --------- Pin 17(TX)
Pin 8(TX) --------- Pin 18(RX)
Other Pins connected for the TCM 120 will be the VCC and GND.
Is there any pins that I missed out or connect wrongly?
Can anyone please help me on this?
Thank you!!
0
