Good day.
board: MCB1700
I've tried all services from SUBJ separatelly. All of them works fine including FTP uploading to the SD-based file system. Then I've joined all of them into the single project. Now FTP's work has some limits: I can download files from SD, I can remove files from SD. But, if I'm trying to upload any files to SD via FTP then crated file has length 0 bytes. Probably some settings missed or meshed.
Thank you in advance for any advice.
No errors indicates in ftp_fclose and ftp_fwrite procedures:
/*--------- ftp_fclose -------------------------*/ void ftp_fclose (void *file) { /* Close the file opened for reading or writing. */ if (fclose (file)==0){ GLCD_ClearLn (6); GLCD_DisplayString(6, 0, "File closed"); } else{ GLCD_ClearLn (6); GLCD_DisplayString(6, 0, "Error in file closing"); } } /*--------------- ftp_fwrite ---------------------*/ U16 ftp_fwrite (void *file, U8 *buf, U16 len) { /* Write 'len' bytes from buffer 'buf' to a file. */ U16 x; x=fwrite (buf, 1, len, file); if (x<len){ GLCD_ClearLn (5); GLCD_DisplayString(5, 0, "Error in write"); } else{ GLCD_ClearLn (5); GLCD_DisplayString(5, 0, "Write done"); } //return (fwrite (buf, 1, len, file)); return x; }
What else could be checked for debugging?
same problem with RTX+HTTP+TFTP+Telnet+SNMP: TFTP clent's progress bar of uploading shows process as well. After finishing - reports "Uploaded xxxx blocks. MD sum = yyy". When I'm checking SD card - file's length = 0
PS. Telnet and SNMP are not effecting to HTTP+FTP or TFTP combination. If I'm using empty SD (so HTTP will not work) - same 0 length of uploaded files.
The project was assembled from Http_demo project by joining files from FTP_demo, TFTP_demo.... projects
Net_debug showed:
TCP: *** Processing TCP frame *** TCP: Src. Port: 4700 TCP: Dest.Port: 1033 TCP: Seq. Num.: 412607758 TCP: Ack. Num.: 305135616 TCP: Flags : PSH,ACK TCP: Win. Size: 65535 TCP: Checksum : 9577 TCP: Frame len: 25 bytes TCP: Mapped to Active Socket 6 TCP: Socket 6, State CONNECT... 11111 TCP: Socket 6, Sending Control TCP: Src. Port: 1033 TCP: Dest.Port: 4700 TCP: Seq. Num.: 305135616 TCP: Ack. Num.: 412607763 TCP: Flags : ACK TCP: Win. Size: 4380 TCP: Checksum : 17C6 TCP: Frame len: 20 bytes
where 11111 is a content of file which uploaded to FTP. In FTP_demo project content of file do not showed during uploading with Net_debug option.
