In the documentation it's written that it's possible to control uVision remotely with the UVSC library, but the arguments of the UVSC_OpenConnection function don't allow to specify a IP address. How it's possible to control remotely uVision ?
I've looked the UVSOCK API too but I don't understand how to use it...
Thanks.
Exactly, I've read this documentation.
I would like to intall uVision on a PC_1 and control it remotely from a PC_2. My problem is that the UVSC_OpenConnection doesn't take an IP address in its arguments. So how can I establish a connection between PC1 and PC2 (using the UVSC functions) ? Is UVSC_OpenConnection only established a local connection ?
You're right and, from a quick look, I can't see any mention of how to specify a remote host.
In fact, I can't see any documentation of any functions at all for the TCP/IP Connection (UVSOCK)!
I think you need to contact Keil support about this!
