UV4: "Go To Next Output Item" Doesen't work
In UV3 I use the F4 key to jump directly to the lines that was displayed in the output window. (After build or after Find-In-File).
In UV4 this function work's only once. To re-run it I must switch to the output window after every 'jump' - then the F4 works..
Bug?
Any help?
Doron
