I could write the program which utilizes indirect addressing. However while dbugging it does not appear in memory window. I want to preload the values of indirect locations so that I can debug the program. Pleas advice how to do so.
"I could write the program which utilizes indirect addressing"
What program?
If you're still talking about the same program as this: http://www.keil.com/forum/docs/thread16127.asp then continue as a Reply in that thread!
Don't keep starting new threads with every post you make - because then obody can keep track of what you're talking about!!
I am able to write a program of indirect addressing now. It is as under. MOV A,#55H MOV R0,#80H MOV @R0,A MOV A,#00H MOV A,@R0 A = 55H now in register window.
Now in MEMORY WINDOW of debugger I am unable to see this happening. I want to fill the value in locations 80h to 90h by command E C <location> <data> and get back those values in A by just incrementing R0 and giving MOV A,@R0 command.
