Debugging in Simulator LPC2888
There is example:
#include <LPC288x.h>
int main(void){
        PINS_3 = 0x03;
        return 0x00;
and file .ini
$=0x10400000
In debug Simulator line PINS_3 = 0x03;
causes(calls) interruption PAbt_Handler.
Why if PINS is defined in LPC288x.h as
#define PINS_3 (*((volatile unsigned int *) 0x800030C0))?
That to adjust in IDE for correct simulator?
Project is created in MDK-ARM, adjustment by default.
Keil MDK-ARM v3.80a
0
