Just trying to use c function time(), have included time.h, project compiles ok, but the linker reports the following error.
Error: L6915E: Library reports error: __use_no_semihosting_swi was requested, but time was referenced
Have not used time functions with RTX before, is this a re-target issue? Quick search of forum shows similar error linked to file access.
regards Darren
Hi, you should have on project files the Retarget.c . This source file redirect the stdio functions to a specific pheriperal like uart.
In this file you must add the following row:
#pragma import(__use_no_semihosting_swi)
About RTX you shoul use the RTX specific time api and not the std C functions of time.h
A good idea coud be to gain knowledge about semihosting, and RTX.
Regards Maurizio
