I wish to run the “Makefile” I have,there must be a makefile.exe which is usually provided. The Eval copy does not support that so I was not able to directly run the Makefile as I did with the earlier version of RVDS. Do you have any idea whether MDK ARM supports makefile?
No - uVision manages the Project (including building) itself.
If you want to use a makefile, you will have to provide an external make utility.
Can you please provide an example how to provide external utility.. You mean to say through command line?
http://www.keil.com/support/man/docs/uv4/uv4_utilities.htm
www.keil.com/.../uv4_ca_usecustomtranslator.htm
Thanks..
