I'm develooping on STM32F2xxx chip with an evaluation board (provided by ST) under uvision 4 and actually i failed when i trying to call some code written in C++ language. In my project, i use the standard library (not the microlib) and i wonder what i could change in my startup to call the main() function in a .cpp file? If you have any idea or suggestion? it could help me?
Regards
You should not have to change anything. main() should still use the C calling convention, and the tools should manage to make sure that any extra library init calls are performed before reaching main() - besides C++ library initialization, a C++ program must also construct all global objects before main() is entered.
Failed ... how? How do you expect anybody do be able to help you if you don't describe what actually happened?
What made you think you had to change anything to get that effect?
