I am using the keil mcb2300 development board witch the LCP2378 on it. I am trying to enable the RTC but it won't generate interrupts.
I have tried to use the alarm interrupt and the Counter Increment Interrupt. But both types of interrupts won't happen.
The clock tick counter is working but I noticed that the Consolidated Time Register wont't be updated. Does anyone know what the problem is?
void RTC_setup () { PCONP |= 512; //enable power to RTC RTC_CCR = 0x13; /* Reset the clock ,clock from external osc,RTC enable*/ RTC_ILR =0x01; /* Clear the RTC Interrupt */ RTC_CCR =0x11; /* RTC reset changeed to 0 */ RTC_CIIR = 0x01; /*interrupt on Second counter*/ RTC_CISS = 0; VICVectAddr13 = (unsigned long)RTC;/*Set Interrupt Vector*/ VICVectCntl13 = 15; VICIntEnable = (1 << 13); } __irq void RTC(void) { counter++; //FIO2SET = RTC_ILR; // Reset interrupt flag RTC_ILR = RTC_ILR; VICVectAddr = 0; }
RTC_CCR = 0x13;
0x10 = select external 32768Hz oscillator 0x02 = CTC Reset. The elements remains reset until this bit cleared 0x01 = Clock enable
