A MCB1000 LPC1343 based evaluation board recently arrived here and I am trying to make it do something from the Keil Toolchain uVision 4.01.
I am waiting for a 10 Pin Cable for my ULink 2 so I can debug on the chip but in the meantime I thought I would load some Keil/NXP? Provided demos in to the board.
The following webpage made this look all very promising: www.standardics.nxp.com/.../lpc13xx.usb.pdf
The reality is much less promising as I cannot get anything working here.
The first battle I had is that the Keil IDE cannot generate Binary files directly.
I got round this after much head scratching and rather too much digging by finding that a Binary file can be obtained by using "fromelf.exe" post processing in the User Tab of the options. It does not help that the elf file actualy has a .axf externtion, Doh!
I used this command line: "C:\Keil\ARM\BIN40\fromelf.exe --bin --output=Flash/BlinkyBin.bin Flash/BlinkyBin.axf"
I then got a bin file.
If I program this in to the board using the instructions from the NXP Weblink and reset the unit, it comes straight back as a drive.
This implies that the binary file is not a valid one!
I also wanted to try the actaul HID Demo from the NXP link only to find that it is NOT provided as part of the KEIL toolchain as the PDF says.
I emailed KEIL support and they sent me a HID Demo. It was however not the same one as in the PDF and again the Binary file did not work.
Has anybody managed to make a working Binary file for the LPC1343 with uVision and if you have how did you do it?
Life, don't talk to me about life ...
All te best.
Simon R. Ellwood BEng.
Well I keep working on this.
I found more demo software on the NXP site at this link:
www.standardics.nxp.com/.../code.bundle.lpc13xx.keil.zip
I am working on this and will see where it takes me!
> I am waiting for a 10 Pin Cable for my ULink 2 so I can debug on the chip > If I program this in to the board using the instructions from the NXP Weblink and reset the unit, it comes straight back as a drive.
Sound like you are fighting on a bootloader, instead of JTAG connection. I don't have MCB1000, but the board seems with NXP bootloader on the chip.
Then, you have to modify your code, so that it fits to the bootloader. See this section of NXP appnote.
AN10711 USB Secondary ISP Bootloader with Source Files, V2 (Jul 15, 2008) www.standardics.nxp.com/.../an10711.zip
AN10711 USB secondary ISP bootloader 4. Modifying the code
When your ULINK 2 comes, you'll be able to send the code without modification.
Tsuneo
OK, I have this working now.
The Binary file that Keil makes has to have 4 bytes modified in it to make the bootloader happy.
I have used a Perl Script to do the manipulation and now it works.
Pay attention to Endianess when writing the script however.
See page 251 of the User Manual:"Criterion for Valid User Code" to get the details of what to do to the binary file.
All the best.
Hi, could you post the perl script here in the forum? Thanks
regards Daniel
