i2c code for communication between 89c51rd2 and 24c256
hi i have a problem i communicating with 24c256 from 89c51rd2. i have used the same i2c code to communicate with the rtc and it works fine. please help me to solve this problem .....my code is as follows
#include "lcd.h"
#include <REG51.H>
#include<stdio.h>
#include<stdlib.h>
#include<intrins.h>
sbit sda=P2^1;
sbit scl=P2^0;
#define not_ack 0
#define ack 1
void delay_50msec();
void i2cstart();
void i2cstop();
bit i2cclock();
bit i2cwrite(unsigned char );
unsigned char I2CRead(bit );
bit writei2cport(unsigned char , unsigned char );
unsigned char readi2cport(unsigned char );
void send();
void main(void)
{ char byte2='9'; bit status=1;
init_lcd(); cmd_write(0x80); delay_50msec(); data_write(byte2); delay_50msec();
i2cstart(); status=1; while(status=i2cwrite(0xa6)); status=1; while(status=i2cwrite(0x00)); status=1; while(status=i2cwrite(0x00)); status=1; while(status=i2cwrite('6')); i2cstop();
i2cstart(); status=1; while(status=i2cwrite(0xa6)); status=1; while(status=i2cwrite(0x00)); status=1; while(status=i2cwrite(0x00)); //i2cstop(); i2cstart(); status=1; while(status=i2cwrite(0xa7)); status=1; byte2=I2CRead(0); i2cstop(); delay_50msec();
data_write(byte2); delay_50msec(); data_write('4'); delay_50msec(); //send(); while(1);
void i2cstart(void)
{ sda=scl=1; _nop_(); _nop_(); sda=0; _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); scl=0;
void i2cstop(void)
{ sda=scl=1; _nop_(); _nop_(); sda=1; _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); scl=0;
bit i2cclock(void)
{ bit level; scl=1; _nop_(); _nop_(); while(!scl); _nop_(); _nop_(); _nop_(); level=sda; _nop_(); _nop_(); scl=0;
return(level);
bit i2cwrite(unsigned char byte)
{ unsigned char mask=0x80; while(mask) { if(byte & mask) sda=1; else sda=0; i2cclock(); mask>>=1; } sda=1; return(i2cclock());
unsigned char I2CRead(bit a)
{ unsigned char mask=0x80; unsigned char byte=0; while(mask) { if(i2cclock()) byte|=mask; mask>>=1; } if(a) { sda=0; i2cclock(); sda=1; } else { sda=1; i2cclock(); } return (byte);
bit writei2cport(unsigned char add, unsigned char databyte)
{ bit status; status=1; i2cstart(); if(!i2cwrite(add)) { if(!i2cwrite(databyte)) status=0; } i2cstop(); if(!status) delay_50msec(); return(status);
unsigned char readi2cport(unsigned char add)
{ unsigned char khit; bit status=1; i2cstart(); if(!i2cwrite(add|0x1)) { status=0; khit=I2CRead(not_ack); } i2cstop(); return(khit);
void delay_50msec() {
TMOD=0x01;
TL0=0xb0;
TH0=0x3c; TR0=1; while(!TF0); TF0=0;
  • .....my code is as follows
    you have the audacity to call the mess above 'code'?
    code is formatted and commeted and READABLE.
    right above the entry window it reads
    Tips for Posting Messages.
    did you even read them?
