I am trying to port a usb driver from wdm to wdf framework. In wdm there is an api KUsbInterface:BuildClassRequest which "USB client drivers set up this structure to issue a vendor or class-specific command to a device".
I am trying to find a similar api in WDF.
Please help me on the same.
Regards, Zaheer.
That's Windows, isn't it?
So nothing to do with Keil?
For KMDF, WDF_USB_CONTROL_SETUP_PACKET_INIT_CLASS()
"Initialization Functions for USB Structures" msdn.microsoft.com/.../aa939125.aspx
And send it using WdfUsbTargetDeviceSendControlTransferSynchronously() msdn.microsoft.com/.../aa501719.aspx
Tsuneo
I have to port the code from WDM to wdf for dfu driver. Below is the code :
wdm ========
DeviceControl(KIrp I) {
switch (I.IoctlCode ())
case GETSTATE:
GetState();
GetState (KIrp I) {
NTSTATUS status = STATUS_UNSUCCESSFUL;
I.Information () = 0;
if (I.IoctlBuffer () && I.IoctlInputBufferSize () == 0 && I.IoctlOutputBufferSize ()) { status = SendCommand ((UCHAR *) I.IoctlBuffer (), I.IoctlOutputBufferSize (), GETSTATE, 0, true, true, 0); I.Information () = sizeof UCHAR; } else { status = STATUS_INVALID_PARAMETER; }
return status; }
SendCommand (UCHAR * buffer, ULONG size, UCHAR request, USHORT value, bool In, bool ShortOk, ULONG * info) { NTSTATUS status = STATUS_UNSUCCESSFUL;
T.Trace (TraceInfo, "> " __FUNCTION__ "\n");
PURB pUrb = m_DfuInterface.BuildClassRequest (buffer, // Transfer buffer size, // Transfer buffer size 0, // Request reserved bits request, // Request value, // Value In, // In ShortOk, // Short OK NULL, // Link URB NULL); // URB
if (pUrb != NULL) { status = m_DfuInterface.SubmitUrb (pUrb);
if (NT_SUCCESS (status) && info) { *info = (USHORT)pUrb->UrbControlVendorClassRequest.TransferBufferLength; } if (NT_ERROR (status)) { t << "SendCommand (" << request << "): FAILED\n"; t << " NTSTATUS = " << ULONG (status) << "\n"; t << " URB status = " << ULONG (pUrb->UrbHeader.Status) << "\n"; } delete pUrb; } else { T << "SendCommand: STATUS_INSUFFICIENT_RESOURCES" << "\n"; status = STATUS_INSUFFICIENT_RESOURCES; }
wdf =====
EvtIoDeviceControl( IN WDFQUEUE Queue, IN WDFREQUEST Request, IN size_t OutputBufferLength, IN size_t InputBufferLength, IN ULONG IoControlCode ) {
device = WdfIoQueueGetDevice(Queue); pDevContext = GetDeviceContext(device);
switch(IoControlCode) {
code GETSTATE: getstate(pDevContext->WdfUsbTargetDevice,Request);
NTSTATUS getstate(WDFUSBDEVICE Device,WDFREQUEST request) { PURB pUrb = NULL; WDFMEMORY urbMemory; WDF_OBJECT_ATTRIBUTES objectAttribs; PULONG nbytes;
USHORT usUrbSize; WDF_MEMORY_DESCRIPTOR memoryDesc; PWDF_USB_CONTROL_SETUP_PACKET controlSetupPacket;
usUrbSize = (USHORT)sizeof(struct _URB_CONTROL_VENDOR_OR_CLASS_REQUEST);
WDF_OBJECT_ATTRIBUTES_INIT(&objectAttribs); objectAttribs.ParentObject = Device;
status = WdfMemoryCreate(&objectAttribs, NonPagedPool, POOL_TAG, usUrbSize, &urbMemory, (PVOID*) &pUrb);
if (!NT_SUCCESS(status)) { UsbDfu_DbgPrint(1, ("Failed to alloc mem for urb\n")); status = STATUS_INSUFFICIENT_RESOURCES; return status; }
WDF_MEMORY_DESCRIPTOR_INIT_HANDLE(&memoryDesc, urbMemory, (USHORT)sizeof(URB));
WDF_USB_CONTROL_SETUP_PACKET_INIT_CLASS(&controlSetupPacket, BMREQUEST_DEVICE_TO_HOST, BMREQUEST_TO_INTERFACE, DFU_GETSTATE,// Request(DFU_DETACH,DFU_DNLOAD etc) 0, //value 0); //Index
status = WdfUsbTargetDeviceFormatRequestForControlTransfer( Device, WDF_NO_HANDLE, &controlSetupPacket, memoryDesc, NULL ); if (!NT_SUCCESS(status)){ return status; } WdfRequestSetCompletionRoutine( request, MyCompletionRoutine, NULL ); if (WdfRequestSend(request, FmDeviceData->WdfUsbTargetDevice,NULL) == FALSE) { status = WdfRequestGetStatus(request); }
VOID MyCompletionRoutine ( IN WDFREQUEST Request, IN WDFIOTARGET Target, IN PWDF_REQUEST_COMPLETION_PARAMS CompletionParams, IN WDFCONTEXT Context ) { NTSTATUS status; WDFMEMORY memoryHandle=Context; PUCHAR charPointer=NULL; UCHAR count =0; size_t length=0; PWDF_USB_REQUEST_COMPLETION_PARAMS usbCompletionParams;
UNREFERENCED_PARAMETER(Target); UNREFERENCED_PARAMETER(Context); DbgPrint("Entered %s\n",__FUNCTION__);
status = CompletionParams->IoStatus.Status; usbCompletionParams = CompletionParams->Parameters.Usb.Completion;
DbgPrint("%s: request Status 0x%x UsbdStatus 0x%x\n",__FUNCTION__,status, usbCompletionParams->UsbdStatus);
WdfObjectDelete(Request); DbgPrint("Leaving %s\n",__FUNCTION__); return;
Does the above code look good ?. Also how do I get the outputbuffersize and inputbuffersize ?
NO - It does not!
Try using the "pre" tag.
