There is compiler optimisation (O2) which you may want to be aware of.
A while back (Oct 2010) I found a compiler optimisation bug with optimisation level 2 (O2) in MDK V4.12 (Armcc V4.1.0.481). The problem does not occur in MDK V4.11 (Armcc 4.0.0.728).
It appears that in some situations the compiler locates two local variables at the same address. I sent some demo code to Keil and they acknowledged the problem with the following explanation:
It seems like the compiler treats 8bit writes wrongly when analyzing the lifetime of a local variable. It assumes that a whole 32bit value is written and so assumes the other 3bytes in a word are destroyed/rewritten as well. So it can happen local objects share the same location as in this simplified example:
typedef union { char arr[4]; int val; } union_t; void test(char val1, char val2, int *ptr) { union_t a, b; a.arr[0] = val1; a.arr[1] = val1; a.arr[2] = val1; a.arr[3] = val1; ptr[0] = a.val; b.arr[0] = val2; b.arr[1] = val2; b.arr[2] = val2; b.arr[3] = val2; ptr[1] = b.val; a.arr[0] = val2; ptr[2] = a.val; }
This has not been fixed in MDK 4.14.
Has Keil/ARM confirmed this...?
Ho, I thought it was a separate issue. Sorry for the noise.
