I'm using uVision 4 with the MCB2300 development board. I'm developing a software that periodically transmits data (status information) from the device to the host (as first step, the data are sent without being explicitly requested by the host as soon as a connection has been established). Thereto I've modified the USBCDC example included with uVision. The software transmits 20 bytes periodically, using USB_WriteEP (in usbhw.c, which uses the register interface). This works fine so far. Now I would like to use the DMA engine to avoid copying the bytes word by word into the register. I've enabled DMA in the USB configuration for logical IN endpoint 2 (physical endpoint 5 which is called CDC_DEP_IN in the example), and I have managed to set up DMA descriptors. But how do I trigger a DMA transfer? I've tried several combinations of USB_DMA_Setup and USB_DMA_Enable. Manually setting the appropriate bit in DMA_REQ_SET to trigger the interrupt results in an error state. What am I doing wrong? Could anyone please give me some hints concerning USB DMA? Thanks a lot. I'll be back in January, after my Christmas vacation. I wish everybody a merry Christmas and a happy new year!
CC
