Hello.
I would like check I2S project from "code.bundle.lpc23xx.lpc24xx.uvision" in MCB2300, with lpc2378. I run Debugger but I can´t see I2S peripheral registers. Furthermore, in "Pin connect block" there aren´t configured pins such I2S functions and there isn´t interrupt vector for I2s in "Vectored interrupt controller", source 31.
I have checked reception I2S ISR is executed in example, bridging TX lines with RX, so peripheral runs. But I can't check correct register configuration (RX FIFO buffer seems without correct value, that it has to content TX register).
Anyone knows how can check appropriated registers for this peripheral in uv3 Debugger??
Thanks a lot.
I installed uvision 4.13 to check I2S registers in IDE debugger. I only can view I2S interrupt vector, but I can´t view all registers associated with I2S peripheral (in "Peripheral" menu doesn´t appear I2S entry).
Any suggestions?
Did you actually check if Keil claim to support this?
Ok, I will try.
You mean you've spent 2 weeks on this without having checked if it's even supposed to be supported...?!
