Calling C function from ISR
I am trying to call a C function from the interrupt subroutine in LPC3250.
When I call the function from a C file, there is no problem. However, when I use a C++ file containing the required function I get an error.
The error says:
Undefined symbol C_Irq_Handler (referred from lpc32x0.o)
How can I call the function from the C++ file?
Thanks for your help.
  • This is a standard C/C++ FAQ question.
    You have to do something like:
    extern "C" void myfunction(int);
    to inform the C++ compiler that it should call a C function, and not a C++ function. How else would the C++ compiler be able to know that you are mixing C and C++ code?
    To be type safe, C++ augments the symbol names with data type information, so a call to a C++ function creates a reference to the augmented name - and the linker will then look for this symbol, instead of just the function name. The use of name mangling allows you to have a function my_func(int) and another function my_func(float).
  • Thank you very much. I handled the problem with your help.
    Have a nice day.
