UART Simulator don't work
Hello all,
i try to execute the following program under µVision-V4.00-Simulator but the Serial Window shows nothing. By debugging the programm comes to rest upon sth putchar('A');
Please help me.
the code is:
#include <LPC21xx.H>
#include <stdio.h>
int main(void)
{ UART0 (); //Initilise the UART
putchar('A');
while(1)
{ printf("\n\n\nHello World, well its traditional \n"); //Call the prinff function
void UART0 (void)
{ PINSEL0 = 0x05; // Select TxD and RxD on pin connect block
U0LCR = 0x80; //Enable programming of divisor latches
U0DLL = 0xC2; //Program the divisor latch for 19200 baud
U0DLM = 0x00;
U0LCR = 0x33; //Program the line control 8\N\1
U0FCR = 0x4F; //enable the FIFO's
#define CR 0x0D
int putchar (int ch);
{ /* Write character to Serial Port */
if (ch == '\n') { while (!(U0LSR & 0x20)); U0THR = CR; /* output CR */ } while (!(U0LSR & 0x20));
return (U0THR = ch);
  • Hello Robert Benoit,
    Did you select the correct serial window?
    For UART0 please open Serial Window - UART #1.
    Please see also Blinky example in C:\Keil\ARM\Boards\Keil\MCB2130\Blinky Targte Simulator. This example uses UART1 but this should make no difference.
    For UART1 please open Serial Window - UART #2.
    Best Regards,
    Martin Guenther
  • Hello Martin,
    1000 Thanks for your advice.
    There is a very importent C-codes in the Retarget.c:
    #include <stdio.h>
    #include <rt_misc.h>
    #pragma import(__use_no_semihosting_swi)
    extern int sendchar(int ch); /* in serial.c */
    struct __FILE { int handle; /* Add whatever you need here */ };
    FILE __stdout;
    int fputc(int ch, FILE *f) { return (sendchar(ch));
    int ferror(FILE *f) { /* Your implementation of ferror */ return EOF;
    void _ttywrch(int ch) { sendchar(ch);
    void _sys_exit(int return_code) {
    label: goto label; /* endless loop */
