Hi
I'm trying to make a scripting function in the debugger, and if possible load a text file and pull lines out to apply different data strings to a communications stack.
The file commands (fopen etc) all seem to relate to flash or ram drives and not the computers drives. Is there a way around this? Or will I have to look to make an include file with the test inputs in?
Rob
You will have to use Visual basic commands to help you open the file. You can use the AGSI libraries to help you.
http://www.keil.com/appnotes/docs/apnt_154.asp
-Kevin ============== A-ha! the RealView Errors and Warnings:
http://www.keil.com/support/docs/3295.htm
Brilliant, thanks very much
