I HAVE ANOTHER QUESTION:
I like to interface the serial port of my PC to a I2C bus. does anyone have a schematic and software for that? thanks advanced.
and another question:
I have to design a master I2C that will command around 100 slaves distributed over 200-307m distance, is there any precautions to consider with such a number of slaves and such distances.
ou are thanks
200-307m
"m" as in meter, millimeter or...?
Well, I2C will not work with 300 meters of distance and 100 slaves. It's not designed for that. It's designed for inter-chip communications on a PCB. You should look at RS-485 instead.
You should look at RS-485 instead. I totally agree with Mike and add you will need 1/8 load transceivers for it.
1/4 will do for now but Murphy states that you will some day run over 128
