multitasking in ARM7
hello,
can I do multitasking in ARM LPC2148.
I want to display on LCD, LED and 7segment at the same time.
is it possible?????
  • Of course it's possible - even an 8051 can do it!
    But it certainly isn't necessary just for what you've described!
  • Almost every microcontroller can do it.
  • do I need to install some operating system like real time Linux???
    I am working with LPC2148. In this project, I am displaying data on LCDs which is continuously changing. also I want to read input ports.
    can it be done like operating system working??? one program for checking i/p ports and second to display data on LCDs. only one is executing for fixed time and after timeout storing its status on stack and second is executing for fixed time..
  • Search keil forum for "RTX". Also inspect your "Options for target...", Target page ("operating system").
  • As Andy has already mentioned, multitasking is not necessary for what you've described.
    A simple supervisory loop processing each module would almost certainly be sufficient.
  • I wrote this at 2008.Nov.04 =>
    int main (void)
            char LFnCR[] = "\n\r";
        init_VIC();
        UARTInit(9600);     /* baud rate setting */
            init_timer();
            enable_timer(0);
            PINSEL2 = PINSEL2 & (~0x08);    // for GPIO 8LED
            IODIR1  = LED8SET;              // for GPIO 8LED
            MSPI_init();
        while (1)
        {                           /* Loop forever */
                    GPIO8LED_show();
                    MSPI7LED_show();
                    UART0rbREAD();
                    if (cmd_ready)
                            UART0sbWRITE( (BYTE *)cmd_string, strlen((const char *)cmd_string) );
                            UART0sbWRITE( (BYTE *)LFnCR     , 2 );
                            UART0sendKICK();
                            memset( cmd_string, 0x00, 32 );
                            cmdstr_i = 0;
                            cmd_ready = 0;
                    KEYS_control();
            // return 0;
    void KEYS_check(void)
            IOPIN0_last = IOPIN0_this;
            IOPIN0_this = IOPIN0;
            IOPIN0_stat = IOPIN0_last ^ IOPIN0_this & IOPIN0_last;
            if ( ( IOPIN0_stat & KEY1 ) == KEY1 )
                    KEY1_pressed = 1;
            if ( ( IOPIN0_stat & KEY2 ) == KEY2 )
                    KEY2_pressed = 1;
            if ( ( IOPIN0_stat & KEY3 ) == KEY3 )
                    KEY3_pressed = 1;
            if ( ( IOPIN0_stat & KEY4 ) == KEY4 )
                    KEY4_pressed = 1;
            if ( ( IOPIN0_stat & KEY5 ) == KEY5 )
                    KEY5_pressed = 1;
            if ( ( IOPIN0_stat & KEY6 ) == KEY6 )
                    KEY6_pressed = 1;
            timer_KEYpress = 2;
    void KEYS_control(void)
            static BYTE GPIO8LED_pos = 1;
            static BYTE MSPI7LED_pos = 0;
            BYTE const HEX_TAB[16] = {
            //     0     1     2     3     4     5     6     7     8     9
                    0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90,
            //         A     b     C     d     E     F
                    0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E };
            if ( KEY1_pressed == 1 )
                    GPIO8LED_show_on = 1 - GPIO8LED_show_on;
                    KEY1_pressed = 0;
            if ( KEY4_pressed == 1 )
                    MSPI7LED_show_on = 1 - MSPI7LED_show_on;
                    KEY4_pressed = 0;
            if ( GPIO8LED_show_on == 0 )
                    if ( KEY2_pressed == 1 )
                            if ( GPIO8LED_pos > 1 )
                                    GPIO8LED_pos--;
                            KEY2_pressed = 0;
                    if ( KEY3_pressed == 1 )
                            if ( GPIO8LED_pos < 8 )
                                    GPIO8LED_pos++;
                            KEY3_pressed = 0;
                    IOCLR1 =    1 << (17+GPIO8LED_pos)  ;
                    IOSET1 = ~( 1 << (17+GPIO8LED_pos) );
            if ( MSPI7LED_show_on == 0 )
                    if ( KEY5_pressed == 1 )
                            if ( MSPI7LED_pos > 0 )
                                    MSPI7LED_pos--;
                            KEY5_pressed = 0;
                    if ( KEY6_pressed == 1 )
                            if ( MSPI7LED_pos < 15 )
                                    MSPI7LED_pos++;
                            KEY6_pressed = 0;
                    IOCLR0 = HC595_CS;
                    SPI_SPDR = HEX_TAB[MSPI7LED_pos];
                    while( 0 == (SPI_SPSR & 0x80) );
                    IOSET0 = HC595_CS;
  • void GPIO8LED_show(void)
            static BYTE GPIO8LED_on = 1;
            static BYTE GPIO8LED_i = 0;
            if ( ( timer_GPIO8LED == 0 ) && ( GPIO8LED_show_on ) )
                    if (GPIO8LED_on)
                            IOSET1 = ~( LED8SET & ( 7 << (18+GPIO8LED_i) ) );
                    else
                            IOCLR1 = LED8SET & ( 7 << (18+GPIO8LED_i) );
                            if ( GPIO8LED_i == 7 )
                                    { GPIO8LED_i = 0; }
                            else
                                    { GPIO8LED_i++; }
                    GPIO8LED_on = 1 - GPIO8LED_on;
                    timer_GPIO8LED = 8;
    void MSPI_init(void)
            //PINSEL0 = (PINSEL0 & 0xFFFF00FF) | 0x00005500;    // Connect SPI
            PINSEL0 = (PINSEL0 & (~(0xFF << 8))) | (0x55 << 8) ;
            IODIR0  = HC595_CS;
        S0SPCCR = 0x52;                         // Set SPI Clock
            S0SPCR  = (0 << 3) |                      // CPHA = 0, [del]
                              (1 << 4) |                      // CPOL = 1, SCK [del]
                              (1 << 5) |                      // MSTR = 1, SPI [del]
                              (0 << 6) |                      // LSBF = 0, SPI [del]
                              (0 << 7);                               // SPIE = 0, [del]
    void MSPI7LED_show(void)
            static BYTE MSPI7LED_i = 0;
            //         A     b     C     d     E     F
            if ( ( timer_MSPI7LED == 0 ) && ( MSPI7LED_show_on ) )
                    IOCLR0 = HC595_CS;                              // 74HC595
                    SPI_SPDR = HEX_TAB[MSPI7LED_i];
                    while( 0 == (SPI_SPSR & 0x80) );            // Wait
                    IOSET0 = HC595_CS;
                    if ( MSPI7LED_i == 15 )
                            { MSPI7LED_i = 0; }
                    else
                            { MSPI7LED_i++; }
                    timer_MSPI7LED = 95;
  • void Timer0Handler (void) __irq
      timer_counter++;
      if ( timer_KEYpress != 0 )
        timer_KEYpress--;
      else
        KEYS_check();
      if ( timer_GPIO8LED != 0 )
        timer_GPIO8LED--;
      if ( timer_MSPI7LED != 0 )
        timer_MSPI7LED--;
      T0IR = 1;                     /* clear interrupt flag */
      VICVectAddr = 0;              /* Acknowledge Interrupt */
  • The above code which I posted, is a [low quality] demonstration for:
