HI,
I am using Phytec LPC3250 board.
I want to flash LED Blinky example in Block 1 of the Ext.NAND Flash and which I want to run it in IRAM.
In keil software I have an option to load the program directly into NAND Flash using <download/b> option, but where I have to mention the code size and from which address location I want to store the code ?
And how to load the size information in Page 0 of that block ?
Can you please help me how to and where I have to mention the memory addresses? I am getting confusion while mentioning the addresses in Keil Software tools(Target Settings).
Regards, Bharathi.
how to load the size information in Page 0 of that block? For this you can check Nand Flash Algorthim provided by Keil at following Location
C:\Keil\ARM\Flash\LPC3000_NAND_SP
