hey anyone plz give code for accessing data (reading and writing files) from pen drive which is connected to usb host and usb otg plz reply as soon as possible
thanks for replying but can you provide me some links or examples plz i am new to embedded system and i am finding it hard to acessing file content from pen drive which is connected to usb host and otg
In that case, I think you're probably being a bit ambitious with this at this stage.
Probably better to start gaining experience with something simpler...
http://www.keil.com/books/
Hey dude i need code (low level I/O) for controlling data access from pen drive which are connected to MCB 2300 (LPC-2388) board i will do reverse engineering and understand the code i don't have much time as i need to submit my project in one week plz help and plz reply as soon as possible
There's the thing: you need to submit your project; that means a project that you have done yourself - not somebody else's work!
my project is big n its halted because i cant access files from pen drive connected to otg n host of mcb2300 i can access from memory card any help is appriciated
if u can help then its ok or else finally i will have to write driver code and i will do it but i will post that code so other who don't have time can use that code thanks for replying to me
Why not - what is preventing it?
What have you tried?
Where is it going wrong?
wait i need time to try hard
Yes, that is true!
To access the file from pen drive is it neccessary to implement USB Host and USB Client Stack ?
"To access the file from pen drive is it neccessary to implement USB Host and USB Client Stack ?"
Think about:
* What does a USB Host stack do?
* What does a USB Device (or "Client") stack do?
How does either/both relate to reading from a pen drive?
Or ask yourself, "is a pen drive a Host or a Client?"...
pen drive is client!!!!!!!!!!!
Very good.
So, then: what does your software need to be in order to talk to a USB pen drive as its Client...?
