I am using the P89c669 micro controller and I want to use the EDATA memory of the MCU as the general purpose data memory. I have included the START_MX.A51 file in the my code. So please tell me what changes I need to do in this file to access this extra data memory.
thank You. Pravin
a general answer:
in (a renamed local version of) startup.a51 you need to set the appropiate SFR to match your memory configuration
This should be described here:
http://www.keil.com/appnotes/docs/apnt_160.asp
eg, http://www.keil.com/forum/docs/thread1700.asp
