Hi. who can help me !! my interrupt occure only one time. I dont know why?? can any body help me why my program dosent work correctly? my startup is SAM7.s
thise is my code:
#include "at91sam7x256.h" #include "lib_at91sam7x256.h" #include "delay.h" void Usart0IrqHandler(void); int main (void) {
int rx; unsigned int rxok; int errorcounter;
*AT91C_PMC_PCER=0xC0000040; //Peripheral Clock Enable *AT91C_PIOA_ASR=0X0000003; *AT91C_PIOA_BSR=0X0000000; *AT91C_PIOA_PDR=0x00000003; //Disable I/O,PA5=RXD0,PA6=TXD0 *AT91C_US0_IDR=0xFFFFFFFF; //ALL OFF USART INTERRUPT DISABLE *AT91C_US0_CR=0x000000AC; //RESET RX & TX *AT91C_US0_BRGR=0x139; //BARD RATE:9600 *AT91C_US0_TTGR=0x00000100; //SET TIME GARD=0
AT91F_PDC_Open(AT91C_BASE_PDC_US0); *AT91C_US0_MR=0X8C0; //8bit,No,1Bit Stop,Asaynchron mode *AT91C_US0_CR=0x50; //ENABLE RX & ENABLE tx *AT91C_US0_IER =0x01; //rxbufer full interrupt is set *AT91C_AIC_IDCR=0x40; //DISABLE THE INTERRUOT ON THE INTERRUPT CONTROLLER AT91C_AIC_SVR[AT91C_ID_US0] = (unsigned int)Usart0IrqHandler; // Set the USART0 IRQ handler address in AIC AT91C_AIC_SMR[AT91C_ID_US0] =(0x00000007); *AT91C_AIC_IECR=0x40; *AT91C_AIC_FFDR=0XFFFFFFFF;
while(1){ *AT91C_US0_CR=0x100; rxok=*AT91C_US0_CSR;
*AT91C_US0_IER =0x4; while(rxok==0x1a1b){ rxok=*AT91C_US0_CSR; delay_ms(10); errorcounter=errorcounter+1; if (errorcounter==100) { *AT91C_US0_CR=0xc; // resettx/resetrx errorcounter=0; } } } return 0; } void Usart0IrqHandler(void){
int rx; int i;
unsigned int rxok; int errorcounter; errorcounter=0; kk=kk+1; rxok=*AT91C_US0_CSR; if (rxok && 0x1){ rx=(*AT91C_US0_RHR & 0xff); *AT91C_US0_THR=kk;//rx&0xff; } else while(rxok==0x1a1b){ rxok=*AT91C_US0_CSR; delay_ms(10); errorcounter=errorcounter+1; if (errorcounter==1000) { *AT91C_US0_CR=0xc; // resettx/resetrx errorcounter=0; } };
*AT91C_US0_CR=0x2100; *AT91C_US0_IDR =0x4; rxok=*AT91C_US0_CSR;
for (i=0; i < 8; i++) { AT91C_BASE_AIC->AIC_EOICR = 0; }
return; }
unreadable code. repost.
hi,
without reading the code ...
In some Interrupt Controllers you must acknowledge the interrupt.
In some peripherals with several sources or-ed togather to one interrupt you must also acknowledge the interrupt.
Else it doesn't occur a second time.
BR, /th.
remark:
< pre > code < / pre >
will help you posting code.
As clearly stated in the instructions: www.danlhenry.com/.../keil_code.png
ok. this is my code
#include "at91sam7x256.h" #include "lib_at91sam7x256.h" #include "delay.h" void Usart0IrqHandler(void); int kk=70; int main (void) { volatile AT91PS_USART pUSART0 = AT91C_BASE_US0; int rx; unsigned int rxok; int errorcounter; *AT91C_PMC_PCER=0xC0000040; //Peripheral Clock Enable *AT91C_PIOA_ASR=0X0000003; *AT91C_PIOA_BSR=0X0000000; *AT91C_PIOA_PDR=0x00000003; //Disable I/O,PA5=RXD0,PA6=TXD0 *AT91C_US0_IDR =0xFFFFFFFF; //ALL OFF USART INTERRUPT DISABLE *AT91C_US0_CR=0x000000AC; //RESET RX & TX *AT91C_US0_BRGR=0x139; //BARD RATE:9600 *AT91C_US0_TTGR=0x00000100; //SET TIME GARD=0 AT91F_PDC_Open(AT91C_BASE_PDC_US0); *AT91C_US0_MR=0X8C0; //8bit,No,1Bit Stop,Asaynchron mode *AT91C_US0_CR=0x50; //ENABLE RX & ENABLE tx *AT91C_US0_IER =0x01; //rxbufer full interrupt is set *AT91C_AIC_IDCR=0x40; //DISABLE THE INTERRUOT ON THE INTERRUPT CONTROLLER AT91C_AIC_SVR[AT91C_ID_US0] = (unsigned int)Usart0IrqHandler; // Set the USART0 IRQ handler address in AIC AT91C_AIC_SMR[AT91C_ID_US0] =(0x00000007); *AT91C_AIC_IECR=0x40; *AT91C_AIC_FFDR=0XFFFFFFFF; while(1){ *AT91C_US0_CR=0x100; rxok=*AT91C_US0_CSR; *AT91C_US0_IER =0x4; while(rxok==0x1a1b){ rxok=*AT91C_US0_CSR; delay_ms(10); errorcounter=errorcounter+1; if (errorcounter==100) { *AT91C_US0_CR=0xc; // resettx/resetrx errorcounter=0; } } } return 0; } void Usart0IrqHandler(void){ int rx; int i; volatile AT91PS_AIC pAIC = AT91C_BASE_AIC; unsigned int rxok; int errorcounter; errorcounter=0; kk=kk+1; rxok=*AT91C_US0_CSR; if (rxok && 0x1){ rx=(*AT91C_US0_RHR & 0xff); *AT91C_US0_THR=kk;//rx&0xff; } else while(rxok==0x1a1b){ rxok=*AT91C_US0_CSR; delay_ms(10); errorcounter=errorcounter+1; if (errorcounter==1000) { *AT91C_US0_CR=0xc; // resettx/resetrx errorcounter=0; } }; *AT91C_US0_CR=0x2100; *AT91C_US0_IDR =0x4; rxok=*AT91C_US0_CSR; *AT91C_AIC_EOICR =0x00; return; }
pleas see my code.I think I do it.if value of it is incorrect pleas say me. in data sheet only say that by wirte in EOICR registery we can set end of the interrupt . but dont say anything about its value!!
thanks for replay...pleas help me.
