Hi
My µC is C8051F122.
In µVision2 (version V2.40a and C51 V7.50) i create 2 Lib files. One for code bank 1 and one for the common bank.
These .lib files are linked into a project in Silicon Laboratories IDE. During to the .M51 file the code is located correct in the selected code bank.
I use BL51 linker and with OC51+OH51 i generate .H1, .H2 and .H3 files. Is there any way to create a single hex file instead? According to the Keil homepage it can be done by using HEX2BIN + BIN2HEX. Here i get an error (unable to open hexfile). The file name is 1 character in length.
Then i tried to use the LX51 linker instead, but then i get the following error: L204 invalid keyword, POS 606 in one of the .lib files. When the error message appear a character in path is missing (please note that the path is identical to the one used when BL51 linker is used)
Any one with any ideas to creat either a single hex file from the 3 hex files, or how to get rid of the L204 error message when using LX51 linker?
You can make a single HEX file all in one, but SiLabs FLASH utility doesn't accept it.
Then, you don't need to split it into code banks :-) Monolithic 64 Kbytes code space serves for the entire code, without any overhead to access to banked code.
Tsuneo
Actually the i manged to create a single Hex file. Data is located in bank 2 and 3 as well. Common and bank 1 holds the LIB files only.
My hex file contains the common area multiple times, but this will be no problem since I just ignore these except from one of course.
What is the purpose for you to make the HEX file? Isn't it burning it to SiLabs 'F122 ?
I once posted a related topic on SiLabs forum, www.cygnal.org/.../000735.html
Here is updated version (for USB debug adapter)
0) Apply BL51 linker - SiLabs IDE doesn't fully recognize object generated by LX51
1) OC51 - Convert original banked omf file into separated object files of each bank
> OC51 mycode.omf
mycode.B01, mycode.B02, mycode.B03 are generated.
2) OH51 - Convert each separated object file to HEX file
> OH51 mycode.B01 HEX (mycode_B01.hex) > OH51 mycode.B02 HEX (mycode_B02.hex) > OH51 mycode.B03 HEX (mycode_B03.hex)
3) SRecord - Split banked code area from common code
For Bank 2 and 3 > srec_cat mycode_B02.hex -intel -crop 0x8000 0x0000 -o mycode_B02_b.hex -intel > srec_cat mycode_B03.hex -intel -crop 0x8000 0x0000 -o mycode_B03_b.hex -intel
4) FlashUtilCl - Write them to the FLASH
> FLASHUtilCL downloadusb -E mycode_B01.hex "" 0 0 > FLASHUtilCL downloadusb -B2 mycode_B02_b.hex "" 0 0 > FLASHUtilCL downloadusb -B3 mycode_B03_b.hex "" 0 0
SRecord srecord.sourceforge.net/
Hey
I need the hex file for the bootloader.
By using HEX2BIN and BIN2HEX i have my hex file organised as:
0x00000-0x07FFF Common 0x08000-0x0FFFF Bank 1 0x10000-0x17FFF Common 0x18000-0x1FFFF Bank 2 0x20000-0x27FFF Common 0x28000-0x2FFFF Bank 3
I just will skip the 2nd and 3rd common area in the hex file
