Hello, I've got serious problems with the uVision4 starting a debug session.
1. I hit the debug button in the toolbar. 2. uVision4 starts to upload the programmcode. 3. After successfull upload it says Window Layout in the statusbar and here the trouble start: Sometimes it takes uVision several seconds to get the windows setup. Sometimes it takes way over 30 seconds until uVision4 is ready to debug and sometimes uVision just crashes or freezes.
I must say this is quite an annoying problem with the uVision4 IDE. I like what I've seen so far except this serious problem!
Will this get fixed and is anyone else having similar problems?
Greetings Jan
Sounds good. I am gonna try that in the afternoon.
Best regards Jan
MDK 4.03 with the ULINK2 firmware update works fine :-)
That sounds interesting. Is there a dedicated firmware update for the uLink2 Device? If so... how do I download the firmware upgrade onto the uLink2 device?
The firmware update starts at the first use of the ULINK2 after the installation of MDK403.exe
Uhh okay! I will try that in the afternoon then. When it's useable I can finally switch to uVision 4.
A much better IDE with a lot of new features :-)
