Hello, I've got serious problems with the uVision4 starting a debug session.
1. I hit the debug button in the toolbar. 2. uVision4 starts to upload the programmcode. 3. After successfull upload it says Window Layout in the statusbar and here the trouble start: Sometimes it takes uVision several seconds to get the windows setup. Sometimes it takes way over 30 seconds until uVision4 is ready to debug and sometimes uVision just crashes or freezes.
I must say this is quite an annoying problem with the uVision4 IDE. I like what I've seen so far except this serious problem!
Will this get fixed and is anyone else having similar problems?
Greetings Jan
Jan; I have not seen this particular problem. What version of MDK are you running? Have you reported this bug to Keil Support? They will need full info of your toolset and your computer enviornment. Remember that Keil does not check this forum on a regular basis. Bradford
Hello Bradford, I am using the following toolchain: IDE-Version: µVision V4.00 Beta 3.1 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009
Tool Version Numbers: Toolchain: RealView MDK-ARM: x user Version: 3.80a Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.0.0.524 Assembler: Armasm.Exe V4.0.0.524 Linker/Locator: ArmLink.Exe V4.0.0.524 Librarian: ArmAr.Exe V4.0.0.524 Hex Converter: FromElf.Exe V4.0.0.524 CPU DLL: SARMCM3.DLL V3.80a Dialog DLL: DARMSTM.DLL V1.43 Target DLL: BIN\UL2CM3.DLL V1.50 Dialog DLL: TARMSTM.DLL V1.43
I am contacting the technical support. I tried to gather as much informations as possible first. Best regards! Jan
Greetings all,
I can confirm the same problem. Installed the MDK-ARM V4.01 update, and in uVision4, it's impossible to begin a debug session. The IDE (uVision4) completely freezes, windoze wants to send a bug report (no, thanks..).
Switched back to uVision3 for the time being: No problem there, repeatedly.
Target: LPC2478 with an own hardware, using both the LPC's internal FLASH, plus external FLASH. Debugger: uLink2 .
While downloading the code into FLASH (via uLink2), it's advisable NOT to switch the focus away from the uVision main window because the window seems to freeze (it doesn't, it just stops to update the progress bar). But this was a minor error which also existed in uVision3; the FLASH download completes some time later and the main window gets alive again. Not so with the debugger - the uVision4 window freezes, and doesn't return no matter how long I wait.
Cheers, Wolfgang "Wolf" .
this is why I'm still working with uv3.
There is actually an issue when downloading to flash (which exists with UV3 too, but is less likely to happen). On Windows XP (and newer) Windows itself sometimes marks the uVision window as "Not responding", if you click on it while the flash download is in progress. This does not affect the download itself, but does bring up a dialog that asks to close the "not responding" application. If you ignore that the download will just finish and the debugger should run normal. Is this the issue you describe?
I've been using uv4 since it's formal release with our STR9 project.
Not noticed any problems like those described here.
It might be a Cortex-M3 related problem.
I am using uVision 4.0 and the uLink2 JTAG adapter.
Actually it is quite annoying and I am absolutely not satisfied with uVision 4 in this case.
I have just started to use UV4 via MDK 4.01 and I have both problems.
Sometimes debug in UV4 takes a long time to start, although sometimes its as quick as it is UV3. Initial I thought UV4 had crashed but it just stalls for 30+ seconds. The stalling seems to happen for no apparent reason to me.
I also have the problem with the flash programming. UV3 and UV4 stall and look crashed until program erase/flashing has completed. This has happened to me ever since I upgraded to MDK 3.80. It coincided with an update to our Unlink2 devices caused by the upgrade to MDK 3.80, not sure if this is related?
I think I will have to use UV3 until the first problem is resolved. The second one I can live with but would obviously like fixed.
Stuart
Oh should have said my project is based on an STR9
Jan, is your ULINK2 connected to the PC directly or via a USB hub?
"I've been using uv4 since it's (sic) formal release with our STR9 project."
More care with your punctuation you must take - bad attack of Greengrocer's Apostrophe you have!
I have tried the Unlink2 connected directly to the PC and via a USB hub, and both problems occur both ways.
Hi Matthias, I have the ULink 2 directly connected to the PC. I have not experienced this problem with uVision 3.
Best regards! Jan
This is what I have found.
When debugging for an LH75401 project the debugger returns focus after about 30 seconds but I cannot set or clear any breakpoints (menu selection grayed out).
When I start debugging for our LPC2148 projects the debugger returned focus after 48 minutes. I started the debugger at 3:36 PM, focus finally returned at 4:24 PM. I was able to set and remove breakpoints. I initially thought that UV4 had died but a co-worker suggested that I wait to see if focus ever returned. This is with UV4.01. I imagine that UV4.00 works the same.
Wow! That is a quite serious flaw I must say. I would not have had the patience to wait that long for my debugger to return. Hehe!
What do you guys suggest to do now? I contacted Keil and they wrote that they managed to reproduce the error. But since then I haven't got any answers.
