Hi everybody; Im trying to manage the peripherals in a XC164CS device while the main program is executing. I belive that the SYSCON3 register is protected because when I try to writting in it, the initial value remains and don't change. Am I right? How do you unprotect this register? Thank you very much.
I think you are correct. This is a Dave tool generated function to unlock protected registers. You can call it prior to modifying SYSCON3.
//**************************************************************************** // @Function void MAIN_vUnlockProtecReg(void) // //---------------------------------------------------------------------------- // @Description This function makes it possible to write one protected // register. After calling of this function and write on the // protected register is the security level set to low // protected mode. // //---------------------------------------------------------------------------- // @Returnvalue None // //---------------------------------------------------------------------------- // @Parameters None // //---------------------------------------------------------------------------- // @Date 11/6/2009 // //**************************************************************************** // USER CODE BEGIN (UnlockProtecReg,1) // USER CODE END void MAIN_vUnlockProtecReg(void) { uword uwPASSWORD; if((SCUSLS & 0x1800) == 0x0800) // if low protected mode { uwPASSWORD = SCUSLS & 0x00FF; uwPASSWORD = (~uwPASSWORD) & 0x00FF; SCUSLC = 0x8E00 | uwPASSWORD; // command 4 } // end if low protected mode if((SCUSLS & 0x1800) == 0x1800) // if write protected mode { SCUSLC = 0xAAAA; // command 0 SCUSLC = 0x5554; // command 1 uwPASSWORD = SCUSLS & 0x00FF; uwPASSWORD = (~uwPASSWORD) & 0x00FF; SCUSLC = 0x9600 | uwPASSWORD; // command 2 SCUSLC = 0x0800; // command 3; new PASSWOR is 0x00 uwPASSWORD = SCUSLS & 0x00FF; uwPASSWORD = (~uwPASSWORD) & 0x00FF; SCUSLC = 0x8E00 | uwPASSWORD; // command 4 } // end if write protected mode } // End of function MAIN_vUnlockProtecReg
Thank you very much Walt: It works well! :)
