What is default code bank
I have searched through App notes, example programs, help guides, etc., and I cannot find out what the "<default>" option is for the Code Bank field on the properties tab of the Options dialog when you right-click on a file. We are using a somewhat older version of Microvision (V2.40).
I understand the concept of allowing a user to place a code module (file) into whatever bank you want, but how does the linker/locater handle the "default" option. Does if fill the common area first, and then when that is filled go to 1, 2, etc.?
Any help would be appreciated.
Thanks,
Gerry
