LM3S9B96 Flash timeout Problem
I am using Keil toolchain for LM3S9B96
I have the problem of the Flash Timeout message when programming the part with the Keil IDE. The Luminary Micro Flash Programmer works fine, but that doesn't help in Debugging.
The problem with the Keil IDE is intermittent but getting worse, possibly as my code size grows? I have followed the suggestion to edit the programming algorithm in other threads in this forum, but no joy.
This is turning into a serious issue and I will have to change toolchains if I can't resolve this.
Glenn
IDE-Version:
µVision V4.10
Copyright (C) 2010 KEIL, An ARM(R) Company
License Information:
Glenn Graf Analogic Employee
Analogic Employee
LIC=PE7B1-C5IPX-YMF9H-ESN82-QL62Z-JSCWQ
Tool Version Numbers:
Toolchain: RealView MDK-ARM Version: 4.12
Toolchain Path: BIN40\
C Compiler: Armcc.Exe V4.1.0.481
Assembler: Armasm.Exe V4.1.0.481
Linker/Locator: ArmLink.Exe V4.1.0.481
Librarian: ArmAr.Exe V4.1.0.481
Hex Converter: FromElf.Exe V4.1.0.481
CPU DLL: SARMCM3.DLL V4.12
Dialog DLL: DLM.DLL V1.20b
Target DLL: BIN\UL2CM3.DLL V1.69
Dialog DLL: TLM.DLL V1.20b
