µV4: Go command at end of ini file
µVision 4 has a problem when there is a Go command at the end of the ini File, then the debug toolbar does not appear until the target gets stopped from the menu Debug/Stop. Currently I use µVision V4.10 (MDK-ARM 4.12).
Under µVision 3 there was no problem with that.
By the way, is there someone who knows a shortcut for the Debug/Stop menu command?
BR
DW
