CLKOUT problem
I am using LPC1114.
I have configured P0.1 as CLKOUT pin,but in simulation , it is not showing that pin as CLKOUT pin and instead it is showing it as 'reserved'
  • the following my code
    #include "LPC11xx.h"
    #define IER_RBR         0x01
    #define IER_THRE        0x02
    #define IER_RLS         0x04
    #define LSR_RDR         0x01
    #define LSR_THRE        0x20
    #define BUFSIZE         0x40
    #define SystemFrequency SystemCoreClock
    #define SystemCoreClock 12000000UL
    void UARTInit(unsigned int Baudrate);
    void UARTSend(void);
    void UARTRecv(void);
    volatile unsigned char  UARTBuffer[40],RECV;
    int main (void)
            UARTInit(9600);
            while (1)
            UARTRecv();
            UARTSend();
    void UARTInit(unsigned int baudrate)
            unsigned int regVal;
            unsigned int Fdiv;
            LPC_IOCON->PIO1_6 &= ~0x07;          /*  UART I/O config */
            LPC_IOCON->PIO1_6 |= 0x01;           /* UART RXD */
            LPC_IOCON->PIO1_7 &= ~0x07;
            LPC_IOCON->PIO1_7 |= 0x01;           /* UART TXD */
            LPC_GPIO0->DIR |= (1<<1);
            LPC_IOCON->PIO0_1 &= ~0x07;      /*  UART I/O config */
            LPC_IOCON->PIO0_1 |= 0x01;           /* clock out*/
            LPC_SYSCON->SYSPLLCLKSEL = 0x00;    //0-IRC,1-SYS Osc
            LPC_SYSCON->SYSPLLCLKUEN = 0x01;
            LPC_SYSCON->SYSPLLCLKUEN = 0x00;
            LPC_SYSCON->MAINCLKSEL    = 0x00;    //0-IRC Osc,1-PLL i/p,2-WDT,3-PLL o/p
            LPC_SYSCON->MAINCLKUEN    = 0x01;
            LPC_SYSCON->MAINCLKUEN    = 0x00;
            while (!(LPC_SYSCON->MAINCLKUEN & 0x01));
            LPC_SYSCON->CLKOUTCLKSEL = 0x00;     // 0-IRC,1-Sys Osc,2-WD Osc,3-Main clk
            LPC_SYSCON->CLKOUTCLKSEL = 0x01;
            LPC_SYSCON->SYSPLLCTRL = 0x00000180;
            LPC_SYSCON->SYSAHBCLKCTRL |= (1<<12);  // UART CLK enable
            LPC_SYSCON->UARTCLKDIV = 0x01;       /* divided by 1 , like pre-scaler*/
            LPC_UART->LCR = 0x83;                /* DLB=1, 8 bits, no Parity, 1 Stop bit */
            regVal = LPC_SYSCON->UARTCLKDIV;
            Fdiv = (((SystemCoreClock/LPC_SYSCON->SYSAHBCLKDIV)/regVal)/16)/baudrate ;
            LPC_UART->DLM = Fdiv / 256;
            LPC_UART->DLL = Fdiv % 256;
            LPC_UART->LCR = 0x03;        /* DLAB = 0 ,Disable access to divisor latches*/
            LPC_UART->FCR = 0x07;        /* Enable and reset TX and RX FIFO. */
            regVal = LPC_UART->LSR;      /* Read to clear the line status. */
            return;
    void UARTSend()
            LPC_UART->THR = RECV;
            while ( !(LPC_UART->LSR & 0x40) //wait until TEMT=0,i.e. U0THR contains valid data
    void UARTRecv()
            while(!(LPC_UART->LSR & (0x01)));
            RECV=LPC_UART->RBR;
    Please anyone answer these:
    1. Is this code correct in using clocks? 2. I'm not getting 12Mhz signal at P0.1,why? 3. Using this snippet I want to test serial communication,but I'm getting simulation o/p only. I am not getting o/p from micro controller after dumping. why?
