this is a part of my command decoder:
const char Command_D[] = {"D"}; //Command in Memory u8 In_Command[17]; //Command from USART
if (strcmp(Command_D, In_Command) == 0) { Run_Dump(); }
The code is compiled correctly and even works correctly, but the compiler says:
warning: #167-D: argument of type "unsigned char *" is incompatible with parameter of type "const char *"
I don't want to see a warning for each command to be decoded. So how can I work around this issue?
