Keil C
could any provide me with the Keil c library files
serial.h
lcdrout.h
  • Is there a reason why you think these files are part of the Keil C library? And is there a reason why you think that you haven't received them, while other people have?
  • Hi,
    did you download the latest MDK and had a look at the examples?
    If the files are "free" (for use with uVision) they can be found in the examples.
    BR,
    /th.
  • He said very right. There are a lot of examples in the MDK folders. You can find the source files and header files in the "board folders".
    D:\Program Files\Keil\ARM\Boards\Atmel\AT91SAM7S-EK\Hello
    the serial.c file in this folder.
    The serial.h just like below:
    #ifndef __SERIAL_H__
    #define __SERIAL_H__
    /* add the serial function */
    void init_serial (void);
    /* you copy the first line of every small programs from the source file to header file */
    #endif /* __SERIAL_H__ */
    for your reference only
  • Note that the OP didn't even state a toolset - let alone a specific board from a specific manufacturer!
    Therefore there is very little reason to beleive that this is the actual "serial.h" file that he enquired about!
    A quick search of my Keil install folder shows at least three other files also called "serial.h"
    This really goes to show how pointless it is to just ask for a filename like "serial.h" with no other details!!
    And it doesn't seem that the OP is really interested anyhow!
