Variable sharing in RTX-51 Tiny
I am using a global variables for producing timeouts as follows...
volatile tDByte TimerStart=0,TimerEnd=0,TimerInitiated=FALSE,Timeout=FALSE;
there are two tasks....task1:Clock and task2:OperateField which requires timeout...
void task3_Clock() _task_ TASK3
  while(1)
         os_wait (K_IVL,200,0);/*500 ms interval*/
         Seconds++;
         if(Seconds>=59)
          Seconds=0;
         if(TimerStart==TimerEnd)
          TimerStart=0;TimerEnd=0;
          Timeout=TRUE;
          TimerInitiated=FALSE;
         else
          TimerStart++;
void task4_OperateField() _task_ TASK4
  while(1)
   if(TimerInitiated==FALSE)/*If Timer is not fired then fire the timer*/
                                                Timeout=FALSE;
                                                TimerStart=Seconds;  /*Read the current  status of the SW clock*/
                                                TimerEnd=Seconds+10; /*Set timer End as 10 seconds             */
                                                TimerInitiated=TRUE; /*Set flag as timer initiated             */
                                        if(Timeout==TRUE) /*If 10 second timer expired     */
                                                Point1=0x00; /*Then clear the command received*/
in these two tasks are using the same variables.....TimerEnd,TimerStart,Timeout,TimerInitiated...
These variables after time out it is initilized to some values in task3...but when returning to task 4 it restore the previous values....how to share the variables....kindly help me....
