Hi, i want an Assembly language program for my project of home security system in which iam using 89c51 microcontroller. the task in which iam facing the problem is that i am using IR based communication so i want an indication whenever anyone crosses between IR sensors. Kindly send me the codes through which this communication can happen. Kindly help urgently. Haris.
The work "want" appears 3 times in your post. If I were you I'd abandon the Saddam Hussain mentality, and start thinking of paying cash for your latest cheating effort.
But you do realize that your teacher wants you to write that code.
Do you want to disappoint your teacher by sending in the work of someone else?
In that case, we want you to fail.
By the way - what school books did you read to consider your 89c51 processor to have the C251 architecture? Your teacher told you so?
maybe not, a few 'teachers' (who do not qualify as such) will let (maybe even ask) the students cheat just to have a good graduation ratio.
That, however, should not lead to "cheating assistance" since to let those that graduated in copying lose on the world would be a BIG mistake.
The only way to weed out such 'teachers' is (unfortuantely for the 'students') to let their graduation ratio drop. I even doubt it would be unfortunate for the students, what is the value of getting jobs that last a week till you are realized as incompetent.
I'd be happy to do your homework for a small fee. email me at embedhomeworkservice@gmail.com with a copy of your assignment and course syllabus (which must include your professors email address) and I will respond to you within 24 hours with pricing information. I think you will find that my rates are quite reasonable.
If, on the other hand, you actually want to learn how to do your assignment yourself, ask specific questions about specific problems that you are having. Show the users here that you have done at least a little of your own work.
If you want people to write your code for you, then you must expect to pay them in some way or another - money is usually the most convenient way.
In order for someone to write your code for you, they will require a detailed specification of your requirements, constraints, etc.
After studying your specification (and clarifying any issues), potential suppliers will give you a quote of how long the work should take, and how much it should cost.
The Device Database entry for each supported chip lists a number of Consultants having experience with this particular chip: http://www.keil.com/dd/chip/3682.htm
You can also search the entire consultants database: http://www.keil.com/condb/
Your chip supplier may also be able to recommend local design resources
etc, etc,...
