Is it possible to delete all comments from souurce code(/*x*/, //x) by any one command in Keil uVision? Thank you for answer.
Is exist any way how can I delete all comments from souurce code(/*x*/, //x) by any one command in Keil uVision? Thank you for answer.
Big question is: "why?"
No.
But you might be able to do it (them?) using the preprocessor.
But, as Per says, why on earth would you want to do such a thing??!
job security?
getting laid off and are angry?
Because copyright notices are usually in comment form? Bradford
For job security. Is it possible?
Please post your company name, and we'll help get you fired. You are asking us to help you be an illoyal employee or consultant.
It's people with your attitude that are giving developers a bad reputation.
Haven't you realized that you get payed to do a good job. Not to try to get lifetime incomes from supporting badly documented source code.
If you mean, "Is it possible to enhance job security by removing all comments from your code" then the answer to that is more likely to be No!
It was a cynical joke!
As Per says, this could rightly be seen as sabotage, and could get you fired.
Or, at least, get you a reputation for writing unusable code - which would not enhance your career prospects!
Is this guy something or is he something. I have seen so much of this bad written code so far - but it's worse - often there are misleading comments in the code, no design diagrams, no UML, no requirements, no test specifications/results, no design, no nothing. It seems that the OP successfully qualifies to the category of "I'm gonna get my ass grilled, but at least I screwed the boss in the process". Shame on you!
