Hi All, I'm trying to write to the Serial Window #1 at regular interval of time (But not successful yet). To generate the time interval i'm using timer0 of 8051 in 16 Bit Timer Mode 0x01 The values are initialized as shown below TH0 = 0xFF TL0 = 0x00 In the given program below, if I comment all the printf statements It works fine, generates accurate delay as needed (as seen in Debug Session). i.e. TL0 starts incrementing for every clock tick and when it reaches 0xFF, the next clock tick sets the overflow flag which in turn calls the ISR (Interrupt_Service_Routine0), wherein I again set the timer's TH0 and TL0 value. But if I uncomment the printf statements in the program (Func1 and Func2), I don't get accurate time delay (as seen in Debug Session). when control reaches Func1 and passes ahead of printf statement the TH0 and TL0 value changes to 0x06 and 0x52 respectively. As I have understood the timer 0 values should be between FF00 to FFFF (as initialized in the Timer_0_Init and Interrupt_Service_Routine0) Please do correct me if my understanding is not correct
Using Keil IDE uVision2 V2.38a Have selected ,b>Generic->8052 (all variants),/b> in the Options for Target in Project Menu The program is as shown below:
/*------------------------------------------------------------------------------ HELLO.C Copyright 1995-1999 Keil Software, Inc. ------------------------------------------------------------------------------*/ #include <REG52.H> /* special function register declarations */ /* for the intended 8051 derivative */ #include <stdio.h> /* prototype declarations for I/O functions */ #ifdef MONITOR51 /* Debugging with Monitor-51 needs */ char code reserve [3] _at_ 0x23; /* space for serial interrupt if */ #endif /* Stop Exection with Serial Intr. */ /* is enabled */ #define FUNC1 3 #define FUNC2 2 sbit Port1Pin0 = P1^0; sbit Port1Pin1 = P1^1; sbit Port1Pin2 = P1^2; sbit Port1Pin3 = P1^3; unsigned short myFlag = 0; unsigned short count = 0; /* --------------------------------------------------------- */ //Functions (Func1 and Func2)to be called from ISR void Func1() { // printf("Func1\n"); Port1Pin0 = 1; Port1Pin1 = 0; Port1Pin2 = 1; Port1Pin3 = 0; } void Func2() { // printf("Func2\n"); Port1Pin0 = 1; Port1Pin1 = 0; Port1Pin2 = 0; Port1Pin3 = 0; } /* --------------------------------------------------------- */ //Initializing TImer0 void Timer_0_Init(void) { TMOD |= 0x01; TL0 = 0x00; TH0 = 0xFF; ET0 = 1; TR0 = 1; EA = 1; } /*----------------------------------------------------------*/ //ISR for Timer 0 void Interrupt_Service_Routine0(void) interrupt 1 { TR0 = 0; //Deactivate Timer 0 TL0 = 0x00; //Setting timer Initial value again TH0 = 0xFF; //Setting timer Initial value again TF0 = 0; //Set Timer Overflow Flag to 0 TR0 = 1; //Activate Timer 0 ++count; if (myFlag == 0 && count > FUNC1) { //Call Func1 Func1(); myFlag = 1; count = 0; } else if (myFlag == 1 && count > FUNC2) { //Call Func2 Func2(); myFlag = 0; count = 0; } } /*------------------------------------------------------------*/ void main(void) { /*------------------------------------------------ Setup the serial port for 1200 baud at 16MHz. ------------------------------------------------*/ #ifndef MONITOR51 SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 221; /* TH1: reload value for 1200 baud @ 16MHz */ TR1 = 1; /* TR1: timer 1 run */ TI = 1; /* TI: set TI to send first char of UART */ #endif Timer_0_Init(); while(1) { //Do Nothing, wait for Timer overflow which inturn calls ISR ; } }
Thanks for your Time and Help
Since you ever so often have pushed 'read' I'll return the favor
re interrupt conflicts/inteference, read here (ch3)
Well, indeed, being the great advocate of reading the manual that I am I'm already quite familiar with the content of those documents. I can therefore tell you that they do not contain the information I'm after, namely an explanation of why you think your statement is true:
One example of a relevant detail is that if [serial comms are] ISR driven you can't [printf() successfully from an ISR].
We started with this:
you are calling printf from (a function called by) an ISR, that is an absolute NoNo
And moved throught this:
One example of a relevant detail is that if putchar is ISR driven you can't.
Eventually establishing after a lot of wriggling that it meant this:
And now we're still waiting for an explanation of why this is true.
and I'm still waiting for you to read "the bible" and find out
"One example of a relevant detail is that if [serial comms are] ISR driven you can't [printf() successfully from an ISR]."
I've worked with 8051s (and the like) since the 1980s and I cannot think why such a requirement could not be achieved.
OK, it may not be considered the best or the recommended way of doing things, but I think it is achievable.
So ... Please ... Erik ... If you think "the bible" has something that states it is not possible (presumably in an indirect manner), be so kind as to give us the details.
Hello Sausage man,
Look at this quote:
and then
Suggesting something that 'works' in 0.00001% of cases...
Maybe I have filleted down something, but where do you see here that Erik claims it is not possible at all?
"Maybe I have filleted down something, but where do you see here that Erik claims it is not possible at all?"
I was simply going by the contents of the last couple of posts; i.e.,
#1
#2
But if #2 doesn't follow #1, then OK.
I do wonder where the figure of 0.00001% originates - Some clever area of statistical analysis?
Regardless, I'm glad that it is usable in even 0.00001% of cases - Having successfully used very similar techniques for debugging purposes in the past :)
if you e-mail me I will gladly answer; however, since the sardine has consistently replied to my inquiries by stating "read the standards" I can not answer his inquiry by any other means.
Please note that in my "read "the bible"" I have, as opposed to his posts not included any snide remarks about his (lack of) competence.
I will, however answer the 'new' question not from a can: I do wonder where the figure of 0.00001% originates - Some clever area of statistical analysis? just a means of saying 'rarely'
You've skinned it and cut it into steaks. You must have slept through fishmongery 101.
The 0.00001% claim applied to polled serial comms, interrupt driven serial comms was dragged into the conversation as something that would prevent it working entirely.
We're still waiting for an explanation.
First off, I haven't mentioned the 'C' standard once in this thread nor suggested that you read it.
Second, surely it would be a shame for you to deprive the rest of the forum community the benefit of your knowledge, just because you don't want to tell me?
First off, I haven't mentioned the 'C' standard once in this thread nor suggested that you read it. correct, but do you expect me to forget all your snide remarks in other threads
I have, in the above thread, suggested they ask by e-mail. Would it not be even better if YOU found out and posted your finding since (according to you) your answers are so much better/clearer/precise/glorious/perfect/.... than mine.
As I pointed out above I have read it and it does not explain why if [serial comms are] ISR driven you can't [printf() successfully from an ISR].
You claim the answer is contained in that document, but I can't find it. I'm surprised you don't seem to want to take this opportunity demonstrate conclusively that I'm wrong by quoting the part of that document that shows that if [serial comms are] ISR driven you can't [printf() successfully from an ISR]. Obviously you would need to explain how the quote applies to printf() as that document does not make any reference to the 'C' library functions.
You claim the answer is contained in that document, I do not, I 'claim' that understanding the document will make you able to find the answer.
The '51 is not a good processor for "C is C, I do not care about the hardware".
My understanding of that document along with my understanding of Keil's implementation of printf() tells me that it is possible to successfully call printf() from an ISR even when using interrupt driven serial comms.
You're going to have to actually explain precisely what it is in that document that makes it impossible to successfully call printf() from and ISR.
.. the answer has been "read the book"
thus my answer stands.
FINAL RESPONSE IN THIS THREAD whatever bile you see fit to spy
I've read the book and the answer isn't there. The fundamental problem with your stance is that you're trying to use a document to back up an incorrect statement. That just doesn't work.
Thanks goodness for that!
