UART1 issue at 115k baud on LPC2368?
Hi all,
I am trying to get a simple pass thru of data at 115k from uart 1 to
uart 0 on an lpc2368. Both are enabled (powered) and if I use 9600 baud
rates, everything is fine. I'm running the unit off the 4MHz IRC. I
then bumped uart0 up to 115k, had to switch the fractional baud rate
settings. No problem, have 9600 baud message coming in UART1, shooting
out UART0 at 115k.
Then, I tried getting UART1 up to 115k. Should have just been setting
the same values for the fractional baud rate and I'd be in good shape,
right? Not so much. The data coming in is all garbled as if the
fractional change isn't taking.
The UART code is running with receive and transmit interrupts enabled.
I'm running a 1 millisecond timer on timer 0, PWM is active in the
background as well. In addition, I have UART2 running and accepting 1 Hz messages at 9600 baud.
The problem is UART1. Again, at 9600 baud on UART1, the code is all
functioning correctly. But when I bump it to 115k, it cis not receiving correctly.
For what it is worth, here is the init code for UART1:
void uart1Init(uint16_t baud, UCHAR mode, UCHAR fmode)
U1IER = 0x00; // disable all interrupts
U1IIR; // clear interrupt ID
U1RBR; // clear receive register
U1LSR; // clear line status register
// set the baudrate
U1LCR = ULCR_DLAB_ENABLE; // select divisor latches
U1DLL = (UCHAR)baud; // set for baud low
byte
U1DLM = (UCHAR)(baud >> 8); // set for baud high byte
if((baud == B115200) || (baud == B57600)) //Fractional baud rate
needed here!!! 115k and 57.6k are 8.51% error otherwise
U1FDR |= (1 << U1FDR_DIVADDVAL_BIT); //DivAddVal = 1
U1FDR |= (12 << U1FDR_MULVAL_BIT); //MulVal = 12
// set the number of characters and other user specified operating
parameters
U1LCR = (mode & ~ULCR_DLAB_ENABLE);
U1FCR = fmode;
#ifdef UART1_TX_INT_MODE
uart1_tx_extract_idx = uart1_tx_insert_idx = 0;
uart1_tx_running = 0;
#endif
#ifdef UART1_RX_INT_MODE
// initialize data queues
uart1_rx_extract_idx = uart1_rx_insert_idx = 0;
// enable receiver interrupts
U1IER |= UIER_ERBFI;
#endif
Does anyone have any ideas / suggestions to look at on this? I have
electrically scoped the system when it is running at 115k and verified
that the same test data is coming into the port electrically at the
higher baud rate. I just can't seem to get the LPC to suck in the bits
at 115k vs. 9600.
Thanks!
  • Hello, thanks for the response.
    I have verified both with a scope.
    Also, I have a separate uC module sending and receiving on UART1. If I pull that module off and attach it to the PC via an FTDI level converter, it operates correctly in both directions.
    The ARM is sending 115k data correctly out (so it seems that the timing is correct), but is not triggering and / or is showing corrupt data on the receive buffer.
    Here is a snip of my UART1 ISR routine. Both TX and RX interrupt defines are defined...
    void uart1ISR(void)
      UCHAR iid;
      // loop until not more interrupt sources
      while (((iid = U1IIR) & UIIR_NO_INT) == 0)
        // identify & process the highest priority interrupt
        switch (iid & UIIR_ID_MASK)
          case UIIR_RLS_INT:                // Receive Line Status
            U1LSR;                          // read LSR to clear
            break;
          case UIIR_CTI_INT:                // Character Timeout Indicator
          case UIIR_RDA_INT:                // Receive Data Available
            do
              uint16_t temp;
              // calc next insert index & store character
              temp = (uart1_rx_insert_idx + 1) % UART1_RX_BUFFER_SIZE;
              uart1_rx_buffer[uart1_rx_insert_idx] = U1RBR;
              // check for more room in queue
              if (temp != uart1_rx_extract_idx)
                uart1_rx_insert_idx = temp; // update insert index
            while (U1LSR & ULSR_RDR);
            break;
    #endif
          case UIIR_THRE_INT:               // Transmit Holding Register Empty
            while (U1LSR & ULSR_THRE)
              // check if more data to send
              if (uart1_tx_insert_idx != uart1_tx_extract_idx)
                U1THR = uart1_tx_buffer[uart1_tx_extract_idx++];
                uart1_tx_extract_idx %= UART1_TX_BUFFER_SIZE;
              else
                // no
                uart1_tx_running = 0;       // clear running flag
                break;
            break;
    #endif // UART1_TX_INT_MODE
          case UIIR_MS_INT:                 // MODEM Status
            U1MSR;                          // read MSR to clear
            break;
          default:                          // Unknown
            U1LSR;
            U1RBR;
            U1MSR;
            break;
