TCPNet Socket Connection Issue
Greetings,
I am using the LPC2468 and TCPNet.
I have created a socket like so:
tcp_sock = tcp_get_sockettcp_get_sockettcp_get_socket (TCP_TYPE_CLIENT_SERVER, 0, 120, tcp_callback);
   if (tcp_sock != 0)
      /* Start listening on TCP port 80 */
      tcp_listen (tcp_sock, 45);
In my main function I have teh following code:
tcp_init(); //Create and Open Socket For Listening
init_TcpNet( ); //Initialize TCP Stack
while(TRUE)
     timer_poll();
     main_TcpNet();
Stepping through the code reveals that the socket is being created successfully, with a return value of 1. It appears as if the socket is being opened for listening properly as well.
However, when I connect up my client application, and attempt to connect on that port, the debug output says that there are no free sockets.
I have established in the NetConfig.C that there should be a max of 5, and everythign else looks ok.
Am I missing something critical? Any Help would be appreciated.
Doug
