Colleagues,
Some IDEs have autocompletion and/or tool tips, which show things like function arguments, when a function call is being typed. Does uVision4 have something like that? If so, how can it be enabled? Is there a plugin that can provide this type of functionality?
Unfortunately, I couldn’t find anything on this subject in the uVision4 User Guide.
Thanks, - Nick
sorry, this is not supported atm.
BR, /th.
Thorsten; While you are correct in your statement, as a Keil principal you should have pointed the OP to the template functions as a partial work around. Bradford
ok, you are right.
In the menu: Edit -> Configuration you'll find a Tab "Templates". For the C language there are already some pre-defined templates.
When editing src, i.e. type 'for' (w.o. the ticks) and then press CTRL Space and the code appears.
When editing the templates, the pipe '|' sets the cursor position after expanding the template.
