error
with the help of apnt195, i had modified the STM32 usb hid application program.
during compilation, it showing the following error
demo.c(33): error: #147: declaration is incompatible with "BYTE OutReport" (declared at line 20 of "demo.h")
demo.c(56): warning: #167-D: argument of type "BYTE *" is incompatible with parameter of type "char *"
demo.c(58): warning: #167-D: argument of type "BYTE *" is incompatible with parameter of type "char *"
  • Note that char may be signed or unsigned.
    BYTE sounds very much like an unsigned data type.
    Have you checked into making char unsigned?
    By the way - why so very short subject for your thread? How much information is there in "error"? Why not "Error 147 while compiling USB sample code" or something similar?
    Next thing - was this the application note?
    www.onarm.com/.../apnt195.asp
    In that case - why not supply that information in the post?
  • hi,
    thank u for reply.
    i made the correction. it is compiling now. now i got one more problem.
    in the vc++ client program, after making the changes, during compilation it is giving the following error. using projectconverter i had modified the client program to vc++ 6.0
    :\Documents and Settings\Administrator\Desktop\HID_Client\HID.cpp(291) : error C2065: 'localTime' : undeclared identifier
    C:\Documents and Settings\Administrator\Desktop\HID_Client\HID.cpp(291) : error C2100: illegal indirection
    even though i had added #include "time.h"
    in hid.cpp.
    expecting your kind reply.
    with regards
    S.Venugopal
  • Dear sir,
    i want to send multiple byte(ex. 8/16/32 bytes) from STM32 development kit to PC application through USB.
    for that i'm using USBHID on STM32 development side and HID_Client program on VC++ side.
    pls suggest me what are the necessity chages i have to make on both host and client side. also i'm bit confused about USAGE_MIN and Usage_Max.
    pls suggest me any sample examples.
    i made the following changes, code compiled with error. in this device not detected.
    in Hiduser.c
    BOOL HID_GetReport (void) {
    /* ReportID = SetupPacket.wValue.WB.L; */ switch (SetupPacket.wValue.WB.H) { case HID_REPORT_INPUT: GetInReport(); EP0Buf[0] = InReport[0]; EP0Buf[1] = InReport[1]; break; case HID_REPORT_OUTPUT: return (FALSE); /* Not Supported */ case HID_REPORT_FEATURE: /* EP0Buf[] = ...; */ /* break; */ return (FALSE); /* Not Supported */ } return (TRUE);
    #if USB_CONFIGURE_EVENT
    void USB_Configure_Event (void) {
    if (USB_Configuration) { /* Check if USB is configured */ GetInReport(); USB_WriteEP(0x81, &InReport[0], sizeof(InReport)); }
    in demo.c
    void GetInReport (void) { int x = 0, y= 0; x = ADC_ConvertedValue; InReport[1] = x & 0xff; InReport[0] = (ADC_ConvertedValue >> 0x08);
    In client side program
    void CHIDClientDlg::OnInput()
    { // int n; int x,y; char buf[16];
    x = InReport[0]; x = (x << 8); y = InReport[1]; x = x | y ;
    // if (InValue == InReport[1]) return;
    // if (z == x) return;
    // z = x;
    // InValue = InReport[1];
    // for (n = 0; n < 8; n++) {
    // m_Input[n].SetCheck((InValue & (1 << n)) ? 1 : 0);
    // sprintf(buf, "%04d", InValue); sprintf(buf, "%05x",x);
    m_In.SetWindowText(buf);
    with regards
    S.Venugopal
  • Dear sir,
    in the previous post, i typed it has "with error".
    sorry it is "without error"
    with regards
    S.Venugopal
