hi ever body,
how do i download keil software
Use a hammer.
After having selected Keil Evaluation Software, selecting Download and target architecture - where did you get stuck?
i am not getting the software to download can u help me out by sending a link to download the soft ware
If you go to the Products page - http://www.keil.com/product/ - the 4 download links for the available toolchains are clearly shown down the left-hand side of the page. There is also a link to request a physical CD.
OK?
In fact, if you go to the Keil home page - http://www.keil.com/ - there is a very clear link under 'Software Downloads' marked 'Evaluation Software'
It's not exactly hidden, is it?!
If you're having trouble with the downloads, why not contact your local distributor? See the 'Contact' link...
k thanx
one more thread
can i connect the 1.5 voltage batteries in series so they produce 5volts. By this battries can we run the micro controller
Think about it: is 5 a multiple of 1.5...?
I think you need to learn some basic electrical principles before moving on to digital electronics and microcontroller programming...!
:-0
k by placing lm7805 we can get the 5volts?
Yes, but the sum of voltages from the batteries (after taking into account that the battery voltage drops under load) must be enough higher than 5V to fullfill the regulation margin the 7805 requires. A low dropout regulator needs less extra voltage to manage to produce a stable 5V output.
